It is about 3 lbs. but has a higher resolution than the 7" Red LCD. If I was doing a lot of hand held though I would chose the lighter monitor.
Hey Tim, it is quite easy to see, as you point out, that if you work all the time the Carrion won't be the way to go. But for some that don't work on a day to day basis, or even a less than that, the Carrion can indeed save you money.
I haven't heard of any of them needing service, though I can't say I read every single post on the multiple threads going on in all the forum talking about it. Have you heard of any issues? Of course the prospect of having alone of bad turn around service is a big deterrent for people that work all the time.
The cables concern can be dealt with easily though, as someone pointed out, by mounting upside down and flipping the image which the monitor will do for you. The case does have mounting screws on both he top and bottom.
For turning it upside down its easy. Here's an example:
Also note the Switronix Power Cable. I ordered it from Abel Cine. For those that were asking, just contact Abel and ask for the Switronix power cable for the Carrion.
