Robert Andriessen
Is it possible to control multiple red heliums at the same time? Like for instance changing iris on canon lenses?
Technically you can with optional equipment and modules. The question is, why do you want to do this? Depending on the location of any camera in reference to lighting source/s, each camera needs to be controlled separately, unless you are recording a talk show or an interview with controlled lighting. You are going to get into a lot of trouble if all cameras change focus, zoom or anything else, that might be unique to a particular scene, at the same time. That is why even in controlled conditions of a well lit TV studio or a news broadcast, each camera is controlled separately. This goes true in modern TV newscast that use robotic camera pedestals and controls that's been used by major TV channels.
If you are adamant of going thru with all these negations, here are some options. FIY; they are not so inexpensive.
1). Canon RC-IP100 Touchscreen PTZ Joystick Controller(US$1999.95)
2). RED GIG-E Right-to-CAT5E Ethernet Cable (9') (US$120.00)
Hope this answered your question.
I doubt the Canon controller is compatible. Don't know much about the Helium but the Canon XC protocol looks nothing like RCPV1.
For DSMC3 cameras that use the RCPV2 protocol one can use RCPs from Cyanview or Skaarhoj. I built a simple RCP in Companion for free.
Good Luck
With DSMC2 it is possible to have camera on same Group ID be controlled together once you enable the "camera to camera" checkbox in communication menu.Is it possible to control multiple red heliums at the same time? Like for instance changing iris on canon lenses?
The Skaarhoj sticks work with their older (deprecated) Unisketch platform on RCP1.Is that only for DSMC3 or will it work with DSMC2 as well.
Don't know about Cyanview. I'd reach out and ask, they're beyond helpful. Vegas show in April of '23, we had problems with wireless on an FX9. The CEO, in town for NAB, showed up at the gig and rewrote the code on the spot. Team Cyanview for life!
Companion is just a shot box. A button or knob can send out one command or twenty, similarly it can address a single device or multiple with a single action.
Good Luck
