Chris Parker
REDuser Sponsor
- Jan 30, 2007
How long is the cable from the camera to the box going to be?
The unit will come with a cable that is approx 1 meter in length. Longer cable lenghts will also be available, as we are currently looking at cables that can be purchased "off the shelf" so that users everytwhere can find them.
Not sure where you may find a cable "Off the shelf" world wide with 4x Audio (12 cores rqd), 4x Vid, HDMI, 2x USB, Time code (4 cores rqd) and what ever else you wanted to bring from the side, all pre wired to the remote box which may require an EDAC connector or high density Circular plug.
With some anodizing and cuts, it should be practical, operational, light and sleek. Once installed, the idea is to leave it on and protect the connections that are on the camera.
but instead of the 3 full sized xlr's could there be a single multipin that gives the sound dept everything they want, 4 inputs and whatever outs. Nobody should be shooting 4k with cine lenses and Mixing 4 channels at once, it's a 2 person job.
They put too many cables into the damm camera! One is all they should get!
Might be just me - but I LOVE the ability to record 4 audio channels to the camera. My sound mixer can give me a live mix-down + independent tracks (boom, lav, etc.) and it all just rolls into the edit via QT - I will start using my sound mixers BWF as just ... back-up (or when we are running and gunning so hard we can't be teathered)
Our concept for a breakout box has change some since our last posting here. The further we brainstormed on which features to extend to the breakout box, (and which immediate features we would still want accessible directly at the camera) the more we realized that it would be a two-part system. The Panel (Image shown) can operate as is and gives the RED user access to most I/O’s on the camera, with the exception of two channels of audio only. The four video out connections, and the two audio inputs are full size connectors.
We will soon post an updated image of the breakout box concept on this forum. The panel will be available as a standalone purchase, or as a package with the breakout box. In the next few weeks we will be able to update you on a price, and a rough delivery date. All designs and specifications at this point are subject to change.
Here are the current features:
A- Camera Mic input (Assigned to Ch #1) switchable to front or rear input (I) also supplies phantom power.
B- RS232 (loop-thru) connector
C- Hirose 12 pin connector for ENG lenses (start/stop, power for zoom servo)
D- Pass thru channel for HDMI, USB (with protective cover not shown)
E- BNC outputs (switchable for multiple preview outputs).
(Genlock, Preview, Dual-stream 1&2)
F- (2) stereo 3.5mm outputs (operator and sound-person)
G- Timecode IN
H- Timecode OUT
I- XLR input (Ch#1)
J- XLR input (CH#2)
K- Muti-pin port for connection to the BOB4R-1 Break-out box
L- Gasket seals protect camera body connections from water, moisture, dirt and dust.
An FAQ page and a website for this product, and others will be up (hopefully) by the end of this month.
