So let me get this straight. What you're saying is if I put a medium format lens (huge image circle) on a super16 camera (small sensor), the resulting picture (field of view from corner to corner) from the super16 camera vs. the medium format camera would be IDENTICAL?
If what you are saying was true, there would never even be a need whatsoever to discuss crop factors, fields of view, etc.
If you're hard convinced otherwise (which I don't understand why you would be, as experiments would confirm it very quickly), then maybe give Duclos or Clairmont a call...
No, of course not; what we are saying is that every 80 mm (or any other focal length) will yield the same FoV on an Epic at a given resolution. That same 80 mm will (if the image circle of the lens allows it ) give a much wider FoV on a medium format camera, but then again, EVERY other 80mm will give this same FoV on such medium format camera.
was rather confusing (and not correct, I think) and there are still a lot of people who mix up crop factor/FoV/focal lenght, so that might add to this confusion. It is probably all semantics, I guess.True, but the resulting image would be comparable to using a 300mm lens. ;- )
Yousuf, clear, I think we all agree, but also for me this statement was rather confusing (and not correct, I think) and there are still a lot of people who mix up crop factor/FoV/focal lenght, so that might add to this confusion. It is probably all semantics, I guess.
The statement that "the resulting image would be comparable to using a 300mm lens" was the one that I had issue with and one that is simply wrong. The lens will always be the same length , it will always behave like its focal length .
I'm not talking about crop factors, 35mm full frame cameras etc, just the fact that this strange 98mm lens, if you could get it on an epic would behave exactly like any other 98mm lens (if anyone else made one) .
Oh, I thought most folks around would be smart enough to figure this out for themselves...
Isn't it quite obvious that the lens doesn't change optically? As you're only using a crop of the same lens?
I have the 300mm RPP. We used it on a number of shots on our feature and it was sweet. We added my doubler to get some 600mm action, which was even sweeter. Can't comment on the other glass but I can tell you we loved the results from the 300.
Greetings,
Curious to hear folks' thoughts. I'd like to acquire a longer lens to add to my package, partly to get those beautiful out of focus backgrounds. The two candidates that are in my price range (of course if you're aware of others...) are the Red 300/2.8 and the older converted Nikon 200/2. Do you have an opinion on which is more 1) useful in day to day feature production, and 2) beautiful? By beautiful I mean there's a 'vibe' to the shots made with it, it flares beautifully, particularly nice bokeh, etc...
Morgan
http://www.morganschmidt.com
Shane is right.
NO, NO, NO!!! If you put a 50mm medium format lens (big image circle) on a 16mm camera (small sensor), you would get the same FOV on the 16mm camera as you would get by putting any other 50mm lens on it, whether that 50mm lens is made for the 16mm camera, a 35mm camera or the MF camera.
Lenses do not have crop factors. Only camera imagers (sensors, film frames) do.
Guys....
If a 50mm Lens design for FF 24x36 sensor such as the 5D, and used on a x1.3 cropped sensor camera such as the Red One, or Epic MX (eta just make strait mathematical example without going in to inner decimals) then such a 50mm while remaining a 50mm will give you an image equal in field of view of that of a 65mm, and that is a FACT...
Guys....
You are confusing the hell out of each other...
Simple answer has been given... A 50mm is and will always be and remain a 50mm Lens, NO matter were or on what you place that lens!!
HOWEVER...
If a 50mm Lens design for FF 24x36 sensor such as the 5D, and used on a x1.3 cropped sensor camera such as the Red One, or Epic MX (eta just make strait mathematical example without going in to inner decimals) then such a 50mm while remaining a 50mm will give you an image equal in field of view of that of a 65mm on a FF 24x36 sensor, and that is a FACT...
