Beta REDCINE for Build 16...
So far I can start REDCINE 106 and play in 1/4 res.
Switching to 1/2 res and pressing play freezes the RC
I have Dell Precision M6300
with Quatro FX 3600M
Vista 64 (running RC as a admin in 32 bit compatibility mode)
This machine works fine with SCRATCH 4.0 Beta, not even one single hung-up.
Well, I guess RC is not getting all what SCRATCH is getting.
Let me try XP 32 bit and NVIDIA 8800M on Dell XPS
How do I change the 24fps to 25fps in 'Library' ???
Thanks ...
Did your 25 fps clips show up as 24? Strange. Mine read 25 for clips shot with build 15 release. I only had to change the project settings..
if I load all the time base is correct, but when I open a single shot it is read with 24 fps from a 25 fps file. changing ISO setting also don't take affect.... on macbookpro....
can somebody tell us if the TC is right in the header of dpx files ????
thx
rainer
maybe i am stupid, but with pre build 16 stuff iso changing works great.
I'm using it on some Build 15 footage and it is not working at all.
Quad core 3ghz Mac pro
5gb ram
NVIDIA GeForce 7300 GT
Newer build tomorrow with a few of these fixes...
Jim
This happens when i set preview from 1/2 res high to full res medium, up to 1/2 res high picture displays fine. Both full resolution setting generate those pictures, if I open 2K files, I can set them to full res high without a problem , Macbook Pro 1,83 Core Duo 1,5 GB RAM OS X 10.5.3.
thx
rainer
yup.. just resolved this one, that fix will be in tomorrows build. :)
RedSpace
RedSpace
Wow. I must say that RedSpace is an awesome place to be. Almost takes all the fun out of it, though.
I like how Project Format now carries over to Output immediately, and I love the error log. At least now I know when the software is just pretending to render but isn't actually writing anything. :-)
Paste All Color is wonderful! Such a small change makes such a huge difference...
Rune
Simplemente
Mexico
thx
rainer
Yes, same here :
"Load all" loads fine as 25 fps, "Load shot" stays 24 fps.
ISO doesn't work.
Tests done on a new Macbook Pro, build 15, 25 fps footage only.
How do we get the other QT codecs back ? Like DV PAL for offline editing... and Avid codecs ?
Also, I tried to edit the "ImageFormats.cfg" file to add a "DV PAL 16/9" preset (I added the line : "SD Pal",720,576,1.422200,25.000000 at the end of the text file). When I choose it in the menu in RedCine, resolution is fine but aspect ratio and frame rate don't update. Frame rate stays at 24 fps and aspect gets changed to "1.1361".
Rune
Simplemente
Mexico
You can always ignore REDspace and go back to REC 709, REDlog or linear! :-)
Jim
Yes, same here :
ISO doesn't work.
"Load all" loads fine as 25 fps with build 16 too (Macbook Pro)
Output codecs were cut back to bare minimum for the rebuild of REDCINE. Many will be added back in given a bit of time.
Jim
XP 32 and Vista 32 works with its usuall
17:18:28.58 PB: 'ImgProcess', Create a 4096x2048 Pixel Buffer..
17:18:29.80 ERROR: GFX PB(1): Unable to create pixel buffer : ''
17:18:29.80 ERROR: CG: Failed to setup a 4096x2048 pixel buffer..
Dell XPS 1730 fully loaded.
NVIDIA 8800M
4K TIFF export works fine.
QT H.264 works only for 1024x512
Love REDSpace!!
Hey. Quicktimes now render as individual clips without "seperate folders". Now we're talking. Hard to do anything but rendering though as Redcine locks up the computer. Pressed F11 and tried to do something else but that crashed Redcine. Hoping for a send to redline/copy to clipboard button like in Redalert.
Also, the buttons for filename, numbers etc don't work after giving the file a new name. The new name stays. Not a big issue, but a little irritating when you type in wrong.
But good work on this build! I'm liking RedCine more now. See how little it took ;)
Are we getting audio support in RC soon?
Would be nice to hear something stright from RC
From the log firle:
17:01:52.15 INFO : Audio: Microsoft Sound Mapper
: Setup: 44100 Hz, 2 Channel(s), 16 bit
17:01:52.15 INFO : Setup Timeline Player, Session 1
17:01:52.64 INFO : Session start
