Will the combination Atomos Samurai Blade and Red Epic Dragon be frame accurate? I am able to borrow one, to try out an offline workflow with my Red Epic Dragon, but when I tried it out, the conform was not perfect, it was some frames off. Is this suppose to happen? Will I have to manually "sync" it? If I have to, I do not see the point of using this, except when you are finishing the project also with the footage from the Blade.
I tried with the Blade and the original samurai and could only get within 1-2 frames on the start frame. On short projects it's a quick conform but on longer ones... maybe a bit more problematic.
H
