- Thread starter
- Admin
- #41
- Dec 27, 2006
Brian, some good questions.
Pre-amps - Yes, same specs as REDVOLT Expander.
Wifi - Same solid performance as when the shorter RED top plate is installed. Extra metal does not degrade performance.
Monitor feeds - You can still run the EVF and touch LCD at same time. You can run the MON-1 port and touch LCD at same time. You cannot run EVF and MON-1 port at same time.
Lemo and Side Handle interference - You get clearance with the straight Lemo cables from those ports. Right angle connectors have even more clearance.
Teradek Bolt - The antennae of the Bolt do not work work with the Production Top Plate. Plus, the Bolt will take the feed that the EVF / MON-1 port uses.
Does it do 4k out?
...Teradek Bolt - The antennae of the Bolt do not work work with the Production Top Plate. Plus, the Bolt will take the feed that the EVF / MON-1 port uses.
Curious about the location and orientation of the headphone jack (pointing downward), I see many headphone cables getting ripped this way...
The WiFi performance has not been solid, in my experience. It s failed me several times on, for example a russian arm when doing car to car and trying to do just run/stop on foolcontrol with an iPhone X from inside the vehicle.
It would be a great tool if it was reliable, but it is not.
Not going to dive deeply into this, but, obviously, there are a lot factors on coverage, and Mikael outlines them as part of his foolcontrol FAQs. I give you that "solid" is a relative term, fine, but the intent of my post was to indicate that our PRODUCTION TOP PLATE gives the equivalent wifi performance as our standard TOP PLATE - which was the question asked by the poster. And, note, our TOP PLATE exceeds the range of other RED-compatible top plates we have tested, sometimes by 4x.
If you would like to continue the conversation over PM, happy to, as I don't want to put this thread down a rabbit hole : )
It looks like the right product... good weight to function ratio! A sensible addition...
I'd like to know...
how much it pulls power wise?
Does it increase fan noise?
If you can use a block battery to hotswap vlocks?
Ps note to Red (not a moan as I realise dev is expensive) if it was 1k cheaper I would just chance it and buy one to see how it is but at the current price I will wait and see if here is any niggles 1st... the slight issue is I would still need to keep the stuff I have for gimbal work etc and I had a less great experience with he pro I/o module....
Power - about 2W more than an identical setup with REDVOLT Expander + V-Lock Plate.
Fan noise - No impact.
Hotswap - Yes.
Thanks for the info...
because I don't have a redvolt expanders but a base expanders (and ET vlock plates) do you know how much more than this config?
Thanks again
Same config except Base Expander + RED V-Lock plate v Production Module, ~8W more with Production Module.
