Marcus Friedlander
And the REDUSER world thanks you! I know I'll do my part in spreading this proper information around.
Dragon 6K tops out at 100 lp/mm resloving power and based on the photosite ("pixel") pitch of that sensor... And prehaps surprisign to some of you out there, the same holds true for Weapon 8K. That resolving power is just spread out over a larger imaging area.
I'll explain... The easiest and most basic way to think about it is: You need 2 photosites to capture a line-pair off a chart. One photosite to get a black part of a test pattern, one photosite to capture the white next to it. So 6K is 6144 photosites across (not taking into account Bayer pattern or anthing on that level). So to capture a line pair you need 2 photosites, that means 6144/2 = 3072 pairs. Again, resolving power is measured in line-pairs per milimeter... And at 6K, the Dragon sensor is 30.7mm across... So 3072 line-pairs across a 30.7mm sensors is 3072/30.7 = 100.065 lp/mm...
Do that math with 8K and it's exactly the same resolving power. 8192/2 = 4096. 4096/40.96mm = 100 lp/mm. So until the photosite density is increased with a new sensor, Red Dragon sensors are capable of resolving 100 line pairs any day of the week. Now having a lens like a Master Prime or a Summilux that out resolves the sensor is a good thing when you take Nyquist sampling therom into account...
Nick, my example is about as simplified and generalized as it possibly can be. It's not meant to be referenced as dogma, but as way to imagine a person by drawing a stick figure... Be prepared for some mind numbing response from Graeme now explaining why this example misses the point!
What I'm saying is that I see zero evidence Alexa image processing is doing anything special at all with saturation in highlights and what is seen is a natural consequence of the RGB cube.
Being able to pull back bright exposure is purely a consequence of where the DR of the sensor is placed relative to that exposure, and that is because we're talking about essentially linear systems. Of course, once colours clip, response ceases to be linear....
Graeme
There's been talk in another thread about the saturation being radically different on the Dragon, but I've tried to see those differences and I'm not sure I do see them. But I'm experimenting with the LUM vs SAT settings in Resolve and I'm wondering what the "said differences" are? Is it that the saturation is dropping in highlights on the Alexa? Or the mid-tones? I mean if someone like that look, wouldn't the LUM vs SAT settings take care of that and match up good to the Alexa if that is the intended and desired look or starting point? Or, based on the pre-gamma/post-gamma sat, would it be better to dial back the RAW saturation and push up the mid-tones sat in LUM vs SAT as a post-gamma saturation change?
I think the only way to really and scientifically see the differences between these two sensors would be to do like a 3D cam setup so that the cameras shoot a subject at the same time with the exact same point of view, setting the Dragon to 5K in order to get s35mm FOV, using the same and really good lenses like the master primes set to T5.6 and then shoot something with them both, scale them down and up to 4K and have a wipe-slider while playing back. In that way we could really look at different parts of the image and see the actual differences. I mean, if there aren't much difference, it will probably be a good thing to show off that there's not much of a difference. And if someone do want the Dragon to look like Alexa, then that footage would be perfect to match up or create a LUT of some kind to adress saturation differences or whatever. In any case it would make it easier for productions that shoot both.
I tried that but it's not that easy. It has different hues, different saturations, different color lum. The reds on the alexa for example are darker with a different hue. The yellows are less saturated on the Alexa. Every color is different. Saturation levels too. Curves too. You can try to adjust them individually, modify the curve in the middle tones to fit the Alexa etc. But after a while you just degrade your image with weird stuffs especially when modifying individual colors and saturation.
great movie by the way. beautifully shot. and a great use of both cameras.Two films I worked on recently intercut Alexa and Dragon a lot. Dragon often on the Movi. One of those movies is competing at Sundance and I'll be going to check it out next week. I guess seeing it on the big screen will tell me how well they match. Are there differences, sure. The question becomes how well can they be matched to eachother so that the general audience can't see any difference. If anyone will be at Sundance next week, the film is called The Birth of a Nation.
Since DSMC2 bodies now support 3d luts, I wonder of it'd be possible to create a lut that will mimick the Alexa out of camera look and shoot ProRes using it. I guess KipperTie pearl OLPF should help with this too.
