Graeme Nattress
RED Problem Solver
In other threads, Graeme Nattress has claimed that bayer-pattern sensors achieve 70.7% of monochromatic sensors at a reasonable (MTF50?) level. Which means that 2880 pixels should have a horizontal resolution of 2036. That's close enough (99.4%) to the 2048 of DCI 2K to really not make a difference. From an information-theory point of view, scaling down 2880 or 4880 or 8880 pixels to 2048 is not going to give measurably different resolution at 2048 pixels.
At 4K DCI, it's a totally different story. In that case you need 5793 pixels to get a clean 4096 DCI at a "good" MTF level. With up to 6144 pixels, DRAGON far exceeds (> 6%) that number. If 4K matters to you, and you can resolve 100 lp/mm edge-to-edge, DRAGON will wipe the floor with Alexa.
The ~70% figure refers to a naive demosaic approach to theoretically what limiting luma resolution can be achieved from a bayer CFA. That would apply to all bayer CFA sensors. Better demosaics can lead to a higher figure, and stronger optical filtering can obviously reduce this figure. MTF50 is always going to be an awful lot lower than the limiting resolution figure.
I dug up my old measure of this that Jim shot with Leica glass on Alexa and Epic MX. Limiting resolution on the Epic was close to 5k, and MTF50 around 2.5k. On the Arri (shooting 2.8k because they didn't have the newer modes working back then) MTF50 was ~1.2k or thereabouts.
Hope those (albeit old) measured numbers help.
Graeme
