yves d
Project base was supposed to be 24fps. Now playing back the footage isn't slow mo. Do you simply change the project base to 24 in post or am i missing data now?
Yes-- if you set the project base to 24fps, material shot at 30fps should play back as you intended, in slight slo-mo. (I'm assuming that you don't also have footage meant to play back at regular speed 24fps that was accidentally shot at 29.97-- you can change that framerate, too, but it can look a little funny.)
