8K CF Weapon Sensor Upgrade
So does this mean some of our Canon EF primes will cover 8K? What about RED Lenses (we have zooms and primes there too)
Red lenses will not cover, possibly some of the longer ones but not the wides, as they even dont cover the 6k sensor.
Just a very minor detail, but I like how the pixel size is once again exactly 5.0 micron. Makes for an easy calculation to get from 40.96 x 21.60 (mm) to 8192 x 4320 (pixels).
Naturally, the question to follow would be, is this just a bigger slice of optimized Dragon silicon? Or is it new tech?
2 things i'm really curious about:
Datarates / compression at 24 - 60 and 75 FPS
Wider sensor cause vignetting?
I'm in love with this camera. :D
Bigger slice 100%
So is the 8k sensor upgrade 20k with a 10k deposit now or is it only 10k all in during NAB?
I certainly interpret it as its 10k flat. Jarred?
After a lot of frustration trying to upgrade- I'd hit upgrade to my serial number and then 8k, then purchase, I got- no longer available in the cart. The site eventually let me order the 8k upgrade first and then in a separate order the weapon upgrade. Very strange. Hope I didn't end up back too far in line.
This sensor will need to fed by a lens that has 46.4mm image circle..
a schneider Xenon FF lens has a 43.3 mm image circle.. for example..
a 3 mm vignette may occur in the corners,
it looks to be a new path to medium format cine lenses to emerge in the industry
But you'll have a 2:1 ratio. The 1.85 crop could do the trick.
Pat
Finally, comes of age, puts BMD to shame. Been waiting for this for years. Now, Holographic cameras. Maybe that is what that extra wide sensor was about?
Good job, can I have the $5k scarlet 4k fixed version?
