- Thread starter
- #4,881
Erik Widding
REDuser Sponsor
I would still really like to know how much it is going to cost to upgrade the Imperos to work with both the Birger mount and Inclino motors.
The Impero is the same in either kit, whether bought from Birger or ViewFactor. ViewFactor moved to a long range BlueTooth radio for their systme, that is compatible with our shorter range radio BlueTooth. So no more radio swapping is needed.
It is the accessories included in those kits that differ. I think as a rough rule of thumb, you can look at subtracting $600 from a full kit from Viewfactor if you want to reuse the Impero from Birger as part of a Viewfactor system.
If you want to use an Impero bought from Viewfactor with your Birger system, you just need to buy an $85 cable from Birger, and flip a couple of switches inside the battery compartment to make that Impero talk RS232 instead of CAN over the cable.
If you want to use an Inclino from Viewfactor to control zoom with your Birger setup, you will need a $200ish smart cable to go between the mount and the motor. WHich will be available as soon as we get the software to support this in the mount.
Birger and ViewFactor cables are not compatible. Birger cables are pins 2 and 3 crossed over. Viewfactor cables are wired straight through.
