adobe workflow interpretation rules problem
59
www.legendaryfilm.de
Hi, I´m using AE in German - on page 12 of the RED Plugin Workflow Guide is explained how to change the interpretation rules to assign color profiles, but if I change the interpretation rules I get a mistake message for line 138 of the interpretation rules. I think it´s because the changes should be done in german - can somebody provide me the correct german changes? I attached the german interpretation rules.
Thanx
Thanx
Might be typo/syntax error somewhere in the text file... but I can't see any attached file in your post to check line 138...
Sorry, here it is
Sorry, here it is
Hello Mikael,
here´s an extract from the german original and how I changed it:
Original:
# Bedingte Regel: Cineon-Dateien zunächst mit Kodak 5218 versehen
# Nachfolgendes Kommentarzeichen löschen, um Regel zu aktivieren
# *, *, *, "sDPX", * ~ *, *, *, *, "ginp", *
# Bedingte Regel: alle Cineon-Dateien zunächst mit RGB-Arbeitsfarbraum versehen
*, *, *, "sDPX", * ~ *, *, *, *, "wRGB", *
# <SDL>Diese bedingte Regel sollte die letzte in der Liste der bedingten Regeln sein.
# Bedingte Regel: Footage ohne Profil mit sRGB-Profil versehen
*, *, *, *, * ~ *, *, *, *, "sRGB", *
New changed version as explained:
# rule to make red raw files availiable as Rec709
# with Gamma encoded 32bit float data
*, *, *, "R3D", * ~ *, *, *, *, "r7hf", 0
I think it should be written in german, I tried different versions yet, but nothing works.
Cheers
Jürgen
try adding a space " " after the D in "R3D "
those codec codes in AE are always 4 glyphs long
any line starting with '#' is just a comment line for humans. It doesn't matter if it's in german, english or serbian, the software just ignores those lines.
HTH
