- Banned
- #321
CVB
Banned
Check to make sure the GPIO setting for the input is "ACTIVE LOW" and that the output is "ACTIVE HIGH". Also make sure its not in timelapse or varispeed mode. If that doesn't' fix it then is there any way you can test it with another camera? We have see a number of cameras where the GPIOs aren't working correctly. One situation this last week we had an origo on one camera working fine then moved it to another camera and it didn't work. Put it back on the first camera and it was still fine. If it is on our side we will send a replacement but if its on red's side then you'll have to send the camera in for repairs to get the problem fixed.
