Edith Blazek
Active member
- Aug 1, 2022
For me, I yearn for a 65mm camera with a 52-54mm wide and 28-30mm tall sensor in the body form factor of the smaller raptor because i want it to be the professionally acceptable version of the alpa platon where it's truly handholdable with that large a sensor. Would love if they could do 16k dci with a frame rate of at least 33.333 frames per second in hq compression and 90 frames in lq compression and i say these selectively as i know these would work with newer pcie 4.0 based cfexpress type b cards as while id love to be higher, that'd far exceed the abilities of these newer cards if calculations from @Phil Holland frames to data rate tool were to be correct, but id take 14k dci or 12k dci with these framerates for what its worth. What do you think? Are my desires ridiculous? Do they fall in line with what you would want to see if red were to do a 65mn camera? What would you add or want in it?
