Daniel Stilling
- Dec 14, 2009
- US, Denmark
- www.danieldp.com
This is the most bizzare issue I've seen.
I sent a support ticket to RED, but in the meantime I wanted to know if anyone ever faced this issue and what was the outcome.
I have had the latest Beta firmware on my Epic, since it came out. No issues. Today I was prepping this camera and my Scarlet. Manually input the same settings on both and did a black shade at temperature. After that the Epic won't power down. Get's hung up on the red "powering down" screen. I can keep pressing the power button or pull the battery and the camera will obviously lose power. When powered up again it won't give me the "improper shutdown" screen, and everything seems to be working. Seems to be recording without any issues.
After that I tried to downgrade the firmware to the latest non Beta version. I insert the SSD with the "force upgrade" file. The camera gets powered up, fan goes on max, and screen is black. It hangs there. After a long while, I pressed the power button until it went off. Removed the SSD and powered on again. The camera powers up fine, and firmware is changed, but the "force upgrade file" on the SSD is still there, did not get removed. Deleted this file and re-inserted the SSD in the camera. Recorded a little and works fine. Tried to save a log. The camera hangs up on the "saving log file" screen. Have to force shut down. The file does not get saved, but the camera powers on again and seems to work fine. It seems to hang on any process it needs to do...
Any thoughts?
Any thoughts?
