- Moderator
- #41
Brook Willard
REDuser Sponsor
- Dec 28, 2006
- Age
- 41
- Burbank, CA
- www.brookwillard.com
Goodbye, ND 2.1...!
Does the Canon Motion Mount have the same focus and iris control features as the regular DSMC Canon Mount? Is there a projected release date for a Nikon Motion Mount and would it also have the same focus and iris control features?
The Motion Mount Guide states there is IR Cut and Polarizer incorporated. Thats fantastic.
Hows that work? What should I expect from the Polarizer?
Also, is there a way to turn it off?
Basically what you'll be seeing with linear polarizer in vertical orientation is the potential universal effect of reducing glare, unwanted reflections, and enriching colors/increasing saturation in some circumstances. The trick bit here is the angle of orientation vertical, horizontal and 45 degrees can potential produce different results. A bit of experimentation is going to be needed here and I'll do that the day I receive mine.
Although, it being positioned vertically is smart as it will let a good amount of "normal" things through.
The IR Cut you certainly can't turn off. However, I do wonder if there's ways to effect the orientation digitally via the Motion Mount tech to create sort of circular polarizer. I would need to know more about the underlying design, but that might be possible perhaps.
Also a good thing to test out is Quarter Wave filters to see how to fully transform it to a circularly polarized system that you can control.
I missed something. Is the polarizer rotateable? Is it Linear, Circurlar?
I am looking into the Quarter Wave filters btw. Thanks.
And PS im super excited about this. I just lost my mattebox and filters. Lets see how far I can stretch this mount.
Awesome. I'll be looking out for your results
Jarred mentioned using a quarter wave filter to eliminate the polarizing effect.
Googling brings up only PS Technik, as far as I can see.
No pricing or sizing on their website, though.
Does anyone have any info or alternatives?
Hmm? How did you calculate that? ND3 is one stop, so 1.6 stops is approximately ND5. That is a lot.
Damien
