Loren Simons
- Sep 8, 2011
- Los Angeles
- www.redrockmicro.com
DL,
That is an interesting power solution! What kind of voltage will that spit out?
Tom,
As for setting up the camera run stop. We're working on getting a guide together to explain this process but for the time being, here's my quick version.
1) Plug Run/Stop Cable into Basestation's Accessory Port and RED Sync Cable
2) Power on the microRemote
3) BEFORE Calibrating, hold the CAL button, and without releasing it, tap the set button. Then release both.
4) All the system lights will flash either once (arri momentary trigger) OR twice (RED continuos feed).
5) If they only flashed once, preform step 3 again (no need to power cycle) and the system should then be ready to trigger your RED.
6) Calibrate the system on a lens
7) Hit the "Camera" Button on the Wireless Handheld controller. The camera light on the wireless controller and accessory light on the basestation should flash.
The microRemote Basestation will remember your choice of run/stop protocol, and you will only need to do this once!
Tom,
