Suresh Kara
- Mar 11, 2009
- UK London
- www.documovie.co.uk
thanks, do you know if that was from red?
I saw in another thread (can't remember where exactly) that Dragon 6K is 1.2 crop, 5K is 1.3, 4K 1.6 etc... same as MX sensor.
Its not the same, its 10% higher crop factor for equivalent resolutions or a 1.1x relative crop factor. So speaking stricly about horizontal fov, 6k is 1.2x, 5k 1.44x, 4k 1.8x, 3k 2.4x, 2k 3.6x, etc compared to a 36mm wide ff35 sensor.
why dont you understand 5K epic-x and 5K epic dragon is gonna have same FOV
no matter what sensor size
check Phil Hollands Data sheets for more information about crop factor
I don't think it's the same as MX, as the pixels size is different. It's cropping a tiny bit more than MX i think.
RED stated Dragon uses 5um pixels instead of mx's 5.4um pixels... its basic math from the given specs.
MX 5k
5120 x 0.0054 = 27.7mm
Dragon 5k
5120 x 0.005 = 25.6mm
To be more precise, dragon has a crop factor of 1.08x compared to MX at the same resolutions.
I think the difference is actually more than that - but someone correct me if I am wrong.
so according to
http://www.red.com/store/products/scarlet-dragon-upgrade
the MAX IMAGE AREA: 5120 (h) x 2700 (v)
so does that mean it has the same FOV as the MX sensor?
the LENS COVERAGE: 25.6mm (h) x 13.5mm (v) x 28.9 mm (d) is different to the mx of 27.7mm (h) x 14.6mm (v) x 31.4 mm (d)
i'm very bad at maths![]()
thanks sam
i'm still a little confused
i still think i will be shooting a lot of 4k on the scarlet dragon will the FOV be very different @ 4k?
thanks for this
Are there any compression ratio ( redcode ) numbers yet for the Scarlet D modes ?
One think for sure: Red will be selling more Redmags to Scarlet D users, they aren't used to burning through storage with 5K@60 !
Do we know yet about when the Scarlet -> Epic-MX upgrade will take place? I'm sitting here waiting to click "add to cart" and I'm falling farther and farther behind in line... Can we pleease get an update soon? Will it be in July when Dragon upgrades start going out or immediatelyish?
