Mike P.
Well in my case, usually I'd only have mixed lighting when there are tungsten practicals on screen all over the place. So to avoid mix lighting, my options are to replace all practical bulbs with daylight balance (since they can't realistically be filtered without showing on screen), OR, filter the camera/lens, and use a tungsten balanced lighting kit (which, to me, seems easier.) Again, this goes under the assumption that by having a better balance in the camera (read: a cleaner blue channel via CTB), I'd be able to counter-act/compensate for light loss by being able to raise the ISO higher and still have an adequately clean result because of the stronger blue channel.
Obviously they're are other options, but they'd be more expensive and/or time consuming (and the projects where I'd be in this scenario usually don't have much money or crew.) I'm basically looking for a solution that is simple/easy (Set it and forget it) and offers better results than going bare in tungsten. Obviously it would not give better results than actually doing things to the standard.
Before anyone says anything, this side-filtration discussion is related to the topic because the wonkiness is most noticeable in the skin tones.
