Micah Brown
Firmware that actually makes a product better? What a thought!
I have tried all four that i have , 64, 128 and 256 GB in capacity,
so this is a bug?
Confirmed that the refresh rate not saving is a bug. It will be fixed in the next beta release.
So there will be no other way for me to start the camera as remove/plug the monitor cable every time till the next release comes out?
Please try this as a potential workaround:
1) power up the camera
2) under settings -> display -> monitor control set the the Brain LCD frequency to 30 Hz (if there are other default monitor settings you would like, also set those)
3) close the monitor control dialog
4) go to Presets -> Camera Presets -> Create...
5) create a Preset containing 'Monitor Settings' (located under the DISPLAY tab)
6) go to Preset -> Auto Presets -> On Enter Preview and select the preset you just created
7) exit the Preset dialog
Reboot the camera and see if the LCD issue is alleviated.
This will re-apply all monitor settings each time you start previewing live video data.
It worked!! Great, Thank you! At least can start up with live view.
It seem to me, this is a rather isolated case? I don't think, many mentioned that problem.
I noticed something else (the first time) : when I switch from 1:1 to normal view, the video goes very dark almost fades to black, and then pops back to normal. Is this related to the 30 Hz?
Great!
We've had a few isolated reports of this. The only known workaround so far is setting the LCD frequency to 30 Hz. The underlying cause is still under investigation.
The dimming of the LCD when going into magnify is something we're looking into as well. I've repeated it here, but don't have any more info on it yet.
You know guys, I think it's time for RED to produce a wee tutorial on black shading and what you can do with it to get the best from your camera. I know black shading is dependent on exposure, and ambient temperature; should I be thinking about building a little library of different exposure/temperature calibration maps to use as required? Just what's the latitude? How far can you move from an arbitrary standard (say, 24FPS / 180 shutter / 20C) before you should consider applying a different calibration?
Thanks!
Mike
Anyone else having issues with 120fps in 5k WS? I can now only shoot 96fps.
Great update !
But a lot of screen issues !![]()
The only way to format a mag using the REDmote is to have the REDmote in remote mode and drive the camera through its menu system.
Yes a reboot helps, but this didn't happened with firmware v3.3.14 [FONT=FontSiteSans, Helvetica Neue, Helvetica, Arial, sans-serif]on my camera. [/FONT]
So here are the more significant updates summed up in my own words, would you guys say this all seems accurate?
I would kill a stuffed animal (like the ones from a claw machine) for that feature.
