Jannard
Red Leader
- Dec 28, 2006
Sensors are the heart of every digital camera. The company that has the best sensor is most likely to have the best camera.
We at RED have put a tremendous amount of our resources towards sensor development. We do it in house. We do not have outside companies doing the work for us.
There are 3 main characteristics that need to be addressed in sensor development... (no particular order).
1. Dynamic Range
2. Resolution
3. Frame Rates.
Some companies will tell you that 1080P is "good enough" and that dynamic range is all that matters. Not so. Everything matters. 1080P or 2K is not enough. 60fps is not good enough. And dynamic range is the holy grail.
There has been a leap-frog effect recently going on with sensors. Someone has more resolution... then someone has more dynamic range... etc.
Dragon is fire-breathing for a reason. It does everything... times a million. It will have more native dynamic range than any digital camera ever made... way more than film actually. It will be 6K. And it will run at speeds that you expect, over 100 fps.
The incredible thing is that the Dragon sensor is an upgrade. You don't have to buy a new camera to get the advantages of the Dragon sensor. You just need to own an EPIC or Scarlet.
RED is designed for the shooter.... and the owner. We believe in Obsolescence Obsolete. We don't pick your pocket. We are you.
"I've seen things you people wouldn't believe. Attack ships on fire off the shoulder of Orion."
We need you. Our program doesn't operate without you.
Jim
1. Dynamic Range
2. Resolution
3. Frame Rates.
Jim
