Peter Keith
Active member
Does anyone know if the latest beta build allows you to trigger a samurai by hitting the run button without media in the camera!? Cheers
pete
pete
Would this be a Samurai-based issue or a RED-based issue?Also can anyone else confirm whether this happens often or rarely?Just tested it with Scarlet 3.2.16 and Samurai 3.0 Firmware. SDI at 1080 25p. Start trigger worked. Stop trigger didn't.
Just checked again, if I also record on SSD it works (starts and stops), but in ext only mode recording on Samurai doesn't stop and I have to shut down the scarlet by pressing the power button 5 secs - good old pc style - because it won't come out of recording mode.Would this be a Samurai-based issue or a RED-based issue?Also can anyone else confirm whether this happens often or rarely?
In Beta 3.3.3. start/stop works, but record without ssd is not available anymore.
This was a bug with 3.2.16, it is fixed in 3.2.19 and in 3.3Just tested it with Scarlet 3.2.16 and Samurai 3.0 Firmware. SDI at 1080 25p. Start trigger worked. Stop trigger didn't.
Limitation of SDI standard and Disk record speeds.
