Nick Pasquariello
Nick,
GET RID OF FIREWIRE!!!!!!!!!! It is your main problem! Get an eSata card and bump all your drives and Red SSD to eSata. SSD drives connected via firefire are still slow as firewire and a waste. Cheap laptop drives are faster than firewire, so don't waste money on SSD drive until you get rid of firewire.
I would avoid xServe and xSan on set. Your macPro with Atto 6G SAS/eSata card will make your life a ton better. Atto makes one card you can connect 8 eSata devices for about $500 and another that you can connect 16 eSata devices for about $1000.
Thunderbolt will be useful when things a re shipping, but a good eSata card and lots of eSata devices will be faster than Thunderbolt.
The little 1u four drive raid that OWC sells is a nice solution. They also have a square version if you don't rackmount your stuff.
http://eshop.macsales.com/shop/hard-drives/RAID/Rack_Mount/
You can config that as Raid 0,1,3,5 and as Clone to make multiple exact copies. In clone mode your computer only sees one disk in the enclosure, but the enclosure writes the same data to all the drive in it. Nice way to make multiple copies with one write. Lots of ways you can use those to improve your situation.
Hopefully that atleast gets you a start.
Dusty
The reason I haven't pushed for eSata is that our G-Drives only gain a slight (about 30%) benefit from it. I had an eSata card in my workstation briefly, and wasn't receiving much of a real world bump from it. However, it's not really the same scenario. I'm also still wrapping my head around bus speeds and bandwidth. Am I right in thinking that all 4 Firewire connections on a Mac Pro are linked and share bandwidth? So, since I've got 3 devices running on the same Mac Pro, I'm "robbing Peter to pay Paul"? Any specs specifically I should be looking at when I shop around for an eSata card?
If that is the case, the bandwidth from good eSata card would really amp things up. Now that you say it, I'm not sure why I wasn't really considering it . . .
And thanks for the OWC rack suggestion. I'm also looking into something from Synologic, now that Graeme mentioned that he uses them for his home/business stuff. OWC is a name that is popping up more and more when I look into storage; people seem to like them.
