Zeb B
Dumb question: For FOV comparision, what sensor size is the Leica M considered?
Another question about Leica M lenses. As the rear element to sensor distance is very short does this have any effect on using these lenses origional designed for film on an electronic sensor, as the light will strike the sensor at an steep angle. The pixels are effectively down small wells as i understand it. id think the corners and frame edges may be affected propotionaly more than say a PL lens (having a longer rear element to sensor distance) projecting in to the sensor from a greater distance.
Looks promising, thanks for the heads up on that lens!
(Edit) actually upon further review, it does look like it has a protruding element. I saw one photo where it looked like it didn't and got all excited, but most others show a protruding element.
Thanks Pawel......It takes standard 67mm diameter screw-in filters.Ron, just looked at your mount and the the Voigtlander 12mm F5.6 Heliar. They look exceptional. Good work. I will certainly consider them in due course.
Do you know of any good filtering options for the the Voigtlander 12mm F5.6 Heliar?
Thanks for all the previous info.
In regards to the Leica M series lenses, here's a list of Leica M lenses from the Leica website - http://en.leica-camera.com/photography/m_system/lenses/
And here are all the same lenses listed (as out of stock) at B&H-
http://www.bhphotovideo.com/c/search?atclk=Mount+Type_Leica+M&ci=8423&N=4288584243+4293920262
Going by the pictures there, and assuming it's the extra length of the back element that's the problem, it looks to me like these lenses would fit the Epic/Scarlet -
50mm f/0.95 Noctilux-M http://www.bhphotovideo.com/c/product/586190-REG/Leica_11_602_50mm_f_0_95_Noctilux_M_Aspherical.html
50mm f/1.4 Summilux M http://www.bhphotovideo.com/c/product/332585-USA/Leica_11891_50mm_f_1_4_Summilux_M.html
50mm f/1.4 Summilux M - Silver http://www.bhphotovideo.com/c/product/459618-USA/Leica_11892_Normal_50mm_f_1_4_Summilux.html
35mm f/2.5 Summarit-M http://www.bhphotovideo.com/c/product/520349-REG/Leica_11_643_35mm_f_2_5_Summarit_M_Manual.html
50mm f/2.5 Summarit-M http://www.bhphotovideo.com/c/product/520350-USA/Leica_11_644_50mm_f_2_5_Summarit_M_Manual.html
75mm f/2.5 Summarit-M http://www.bhphotovideo.com/c/product/520351-USA/Leica_11_645_75mm_f_2_5_Summarit_M_Manual.html
90mm f/2.5 Summarit-M http://www.bhphotovideo.com/c/product/520352-USA/Leica_11_646_90mm_f_2_5_Summarit_M_Manual.html
50mm f/2.0 Summicron M http://www.bhphotovideo.com/c/product/86059-USA/Leica_11826_50mm_f_2_0_Summicron_M.html
75mm f/2.0 APO Summicron M http://www.bhphotovideo.com/c/product/378040-USA/Leica_11637_75mm_f_2_0_APO_Summicron.html
90mm f/2.0 APO Summicron M http://www.bhphotovideo.com/c/product/162726-USA/Leica_11884_90mm_f_2_0_APO_Summicron.html
135mm f/3.4 APO Telyt M http://www.bhphotovideo.com/c/product/162727-USA/Leica_11889_Telephoto_135mm_f_3_4_APO.html
But these wouldn't fit -
21mm f/1.4 Summilux-M http://www.bhphotovideo.com/c/product/586191-USA/Leica_11_647_21mm_f_1_4_Summilux_M_Aspherical.html
24mm f/1.4 Summilux-M http://www.bhphotovideo.com/c/product/586206-USA/Leica_11_601_24mm_f_1_4_Summilux_M_Aspherical.html
35mm f/1.4 Summilux-M http://www.bhphotovideo.com/c/product/720355-USA/Leica_11663_35mm_f_1_4_Summilux_M_Aspherical.html
35mm f/2.0 Summicron M http://www.bhphotovideo.com/c/product/134723-USA/Leica_11879_35mm_f_2_0_Summicron_M.html
35mm f/2.0 Summicron M Chrome http://www.bhphotovideo.com/c/product/134722-USA/Leica_11882_35mm_f_2_0_Summicron_M.html
28mm f/2.0 Summicron-M http://www.bhphotovideo.com/c/product/214061-USA/Leica_11604_Summicron_M_28mm_f_2_0_Lens.html
28mm f/2.8 Elmarit-M http://www.bhphotovideo.com/c/product/461972-USA/Leica_11606_28mm_f_2_8_Elmarit_M.html
18mm f/3.8 Super-Elmar-M http://www.bhphotovideo.com/c/produ...1649_18mm_f_3_8_Super_Elmar_M_Aspherical.html
21mm f/3.4 Super-Elmar-M ASPH http://www.bhphotovideo.com/c/product/798854-REG/Leica_11145_Super_Elmar_M_1_3_4_21mm_ASPH.html
24mm f/3.8 Elmar M http://www.bhphotovideo.com/c/product/586192-REG/Leica_11648_Wide_Angle_24mm_f_3_8.html
16-18-21mm f/4 Tri-Elmar-M http://www.bhphotovideo.com/c/product/461971-USA/Leica_11642_Tri_Elmar_M_16_18_21mm_f_4_Asph.html
As Jarred stated earlier, it's mostly the wider lenses that don't fit. Unfortunately that includes a lot of the higher quality lenses too.
Something to think about perhaps.
We have been studying the problems associated with shallow ray angles on the peripheries of the Epic sensor, cover glass and filter window for over a year now. Briefly the smaller sensor size mitigates fall-off and fringing as compared to the Leica M9 sensor and the problems seem to be generally less that anticipated. There is no easy way to evaluate performance of these lenses other to look at the image itself.
insert:
Yes exactly you have to see what one is willing to put up with or may be for most applications not visible at all or is in fact perfectly fine.
We have conducted many tests just this way and have modified certain lenses to fit into the dreaded "cave" leading to the filter window. On the wide end to date, we have seen wonderful results from the rectilinear Voightlander 12mm F5.6 Heliar with center performance rivaling some Leica M Glass. We continue to examine lenses for potential modification and use on the Epic and we have identified several other very interesting candidates. We will keep the "community" posted.
Insert: That would be fantastic, will make formal contact etc.
As an interesting aside, a few years ago I designed a successful viewfinding system utilizing a very low light digital camera that looked at the image being focused on the surface of 35mm film as it was exposed in the gate of a camera. This necessitated an angled and perspective-changing optical path. We encountered major fall off problems of course, but surmised that this mainly came from the cover window plate on the sensor itself. This was then removed carefully and the fall-off disappeared completely....wouldn't recommend this procedure here though!!
