Brian D. Goff
REDuser Sponsor
- Apr 18, 2007
- Age
- 57
- Switzerland
- www.actionproducts.ch
The Riser and Audio-Riser are now shipping. The "Top mount pro" and "Power distributor" are in the works. Both accessories expand the EPIC brain to a new level, by adding the missing links: Power sockets and better accessible BNC's - enjoy!
Bottom mount featuring:
-2 x 3.5mm jack plug to Pro XLR at rear
-acts as spacer to use industry standard base plates
-accepts upcoming 15mm light weight rod assembly
-Tape measure hook on left and right
15mm light weight rod assembly featuring:
-Works with Audio-Riser
-Protects 3.5mm Audio Plugs and hides them neatly
-15mm DSMC centered standard
Top mount Pro features:
-power sockets the EPIC lacks (requires power source like a V-mount battery).
-Provides BNC connectors for HD-SDI (the current EPIC BNC is located in a difficult to get spot and this is an very important BNC)
-SS/GPI; TC; GENLOCK BNC's (rather than the small 4pin connector the EPIC uses).
Power distributor features:
-rugged Battery mount for the EPIC (V- Mount, Anton Baur, ect.); can be mounted so battery looks down for more compact configuration
-use of different power sources over RED 5pin Lemo and industry standard 4pin XLR.
-also it brings the Audio plug to a user friendly location
-provides stabilized 12V and 24V power sockets.
All milled with swiss precision and 7075 grade aluminum
