All Canon, Nikon and PL mount lenses are excluded.• Sony E-mount
• Sony Alpha lenses, Minolta and Konica Minolta AF lenses via adaptor
(MF only, exclude power zoom lenses/tele-converters)
As camera's life circles shorten, the main investment is shifted towards lenses. With Sony's new camera you would have to start with a new system and start investing in lenses that support:
To make use of the electronic functions of the lenses, you would lock yourself into the Sony E-mount ecosystem.
This camera might make sense if you already have glass that fits the mount, or if you are starting from scratch and have no plans of going the RED/Canon/Nikon route.
Personally, I'd prefer a camera that lets me use existing lenses, and is more flexible.
But if they come out with a 24/25P enabled version, and if you can plug in something like a nanoflash into it to bypass that 24Mbs AVCHD, you would end up with a very capable system.
Nanoflesh supports GOP compresion scheme and it's not a way to go.
Only ProRes 422 10 bits is appropriate available way to go via AJA KiPro.
That thing is already working with other Sony camcorders:
LINK>>>
I'm pretty sure the cameras only output 8 bit, so using a 10 bit codec is just useless waste of disk space. At up to 288 mbits / sec, i'm pretty sure the Nano Flash compression won't be a problem compared to ProRes either - it should be visually pretty indistinguishable from uncompressed. I'm actually pretty sure it's BETTER than ProRes 4:2:2, as A) long GOP codecs are more effective generally B) data rate is not wasted on useless bits and C) it has a higher overall data rate.
Disclaimer: i haven't used or tested either one of the recorders, so take the above just as an educated guess.
Edit: reading a bit more into it, NanoFlash does both I only and Long-GOP.
sorry it's only your personal "wishes" but KiPro is the best video assistant recorder in the industry...
[snip]you'll get the image quality that can be equal of ALEXA and also with the highest mobility for a fraction or 10% of ALEXA's price.
I can only assume you're joking.
