- Thread starter
- #481
Jannard
Red Leader
- Dec 28, 2006
Where is everyone? I'm feeling generous with info.
Jim
Jim
Question? I'm armed...
Jim
Jim
And finally: if there is a meaning to life, why would anyone chose to capture its beauty in anything less than 4k?
OK...
Redrocket
Will the current Rocket work realtime with Epic material?
Is it the current rocket than eventually will be encoding r3d/RGB material for the (artist formerly known as) Redray?
When will playout from NLEs (similar to a Kona) be available?
Epic.
What's the weight kitted down like a dslr?
You spoke of a switch...
Is that for analogue gain?
My hunch is that Epic will blow the MX'ed REDs away. But in what ways?
(Except 5k/lower compression/weight/longer batterylife/more lens mounts... eh... that was a lot, but still)
The internal processing and image analysing gear inside the epic operates at a higher bitrate (?), so I guess it will give more precission?
Can I come and visit RED for a week and work with you guys this fall?
That's all for now! -![]()
