Zak Forsman
- Dec 29, 2006
- Age
- 51
- Eagle Rock, CA
- zakforsman.com
i'm more or less thrilled by Scarlet's specs so far. if we consider the released spec list as set in stone, there are a couple of things I would hope the Red Team will include.
1. true focus ring, none of that free spinning Sony-style nonsense. lockable for 35mm adapters.
2. manual zoom room, tight, responsive (and lockable for 35mm adapters)
3. OIS, optical image stabalization
4. 48khz, 16bit audio, 2 channels at a minimum, 96khz, 24bit, 4 channels as an ideal.
5. waveform monitoring built-in to the LCD
6. 2.39:1 aspect ratio guides (positionable higher or lower in the frame)
7. manual control of exposure, gain, etc that doesn't require you to dig thru the menu. would prefer tangible dials and button.
8. flip mode - for 35mm adapter users
9. wifi timecode sync between Scarlets
PLEASE no whining about specs that have already been announced here, there's more than enough of that going around. let's operate under the assumption that there is very little wiggle room on those and concentrate on the aspects of this camera that are not necessarily set yet.
