Joel Arvidsson
Say that you have got a little flicker. Whats is the best way to get rid of it with minimal blurring outside of this thin lines?
If you have introduced a little flicker when sharpened, can you deflicker this without softening the image to much. Otherwise you lose the details you just gained with you sharpen. Is there a better way than using masks to protect the thin lines from getting the sharpening.
Or what is you trick to sharpen without introducing flickering thin lines?
