What are the pros and cons of using a top vs bottom rail system for Follow focus?
Enrique Blein
57
Miami Beach, USA
I'm trying to decide whether to go with bottom rails or top rails for a mattebox/follow focus system. So far the only advantage I can see is that with top rails I don't need a raiser, and that Red offers a DSMC 19mm Top Mount with an integrated Swat rail where I can attach the Top handle:
http://www.red.com/store/rail-components/product/dsmc-top-mount-rod-compatible
Any thoughts on this?
If you want to use a matte box, you're probably going to need to go with bottom rods. Is not using a riser worth that much to you? Also, if you flip a follow focus upside down, you're going to reverse the throw, so you need a follow focus with a reversible gear or use backwards throw lenses like Nikons.
I've been scratching my head on this one. One advantage I can think of for those "self operating" is if you are using a shoulder rig that places the Epic/Scarlet below your chin (against your chest) like many have done, top mounting may feel more natural.
However, if on top of your shoulder, and that would be very awkward.
The OConnor CFF-1 has a removable swing arm (mountable an either side) that also rotates 360 degrees. It is possible to mount the unit on top rods; and when in the upright position this maintains the usual “cine” direction of lens rotation. Shown in (poor) pic below...
Last week at RED Studios I used an O-Box Mattebox with a second LWS bracket mounted on top of it with 3” rods. I turned the CFF-1 upside down (top mounted from the 3” LWS mattebox supported rods) to reverse the rotational direction for use with a still photo prime lens on the Scarlet.
I would strongly avise against it. Traditionally follow focus's go under the lens so you don't block the witness marks. You will confuse many 'traditional' focus pullers if you build a rig that HAS to be top mounted. (Not to mention the backwards lens throw).
Also, mounting more weight on the top rods of an EPIC/ Scarlet doesn't sound like a good idea to me..
