It all depends on the job I guess... But for movies and commercial it's the "native" / HQ / RAW format of the camera used most of the time... Sometimes this also involves dual recording of (HD) Proxies together with the internal format - e.g. if an Offline workflow is preferred or for simply getting dailies quick and without transcoding.Don't bother with external recorders shoot internally raw.
1. On the RED you will be recording the line-skipped HDSDI out which will result in more aliasing and moire than if it was a proper downscaled in-camera picture.
I don't know who told you that? The camera output has a really good debayering going on (not to call it half debayer good...).
Pat
Working with Raw we can easily handle white balance/ kelvin adjustments in the post. How about pro res?
Another issue is over-cranking (shooting high speed footage that results in slow motion). Not an issue with RAW, but your only current option for ProRes is to play out the clips from the camera and capture with your ProRes recorder during playback...
This goes for time-lapses as well - basically any footage not shot at your project speed...
:sifone: Peter
No-one told me, I have observed it. When you can see moire and aliasing on the monitors but not on the RAW files then you know that there is some line-skipping going on. That or some sucky downscaling. Either way, not ideal, ask Jim.
:sifone: Peter
Not necessarily. I've worked on lots of Alexa projects that were shot ProRes 444 LogC, and trust me, we had no look baked in -- we had all the room in the world to get different looks out of it in final color. A Log look is not a Rec709 look.That is one of the most important differences between shooting ProRes and RAW. With RAW you set your look in post and have a lots of flexibility to do so... With ProRes the look has to be achieved in camera to as close as you can to your final intent, as the look will be "baked" into the ProRes files...
It's not skipping lines, it's a very good debayer and it's uncompressed HD. possibly you need to change settings on your monitor or change monitor. For high noise / low exposure thats the cleanest HD picture you can get out of MX, with dragon ADD beats it I think.
There are a lot of compromises in recording ProRes on the Red, but I suspect the new Proxy add-on accessory will provide this ability in the near future.
Tried different monitors and settings on the Epic and the monitors. Same result.
Thats a pretty fast debayer then. No wonder the picture has issues.
Hi,
Is there big disadvantage in recording pro res? Is pro res recording good enough for professional work?
Do they record/shoot movies and commercials mainly Raw or Pro res?
