Weapon, Scarlet-W and Raven - difference?
Piero Sgarbi
Boston
A part of the on paper differences, my question is.
If I am shooting at 4k (let's say UHD) across the 3 cameras, using the same compression, would there be a difference on how the footage would look like?
I do know that with the two aside from Raven, you have the option to swap OLPFs depending on your situation. That could make somewhat of a difference.
Yea I know that, but I am actually putting this as if they had all the same lens, olpf, crop factor etc.
I know you said 4K, but if you were shooting 2K ProRes across all cameras, then yes, you'd have a completely different FOV.
Not sure that makes sense... unless I am completely mistaken, the 2K ProRes is derived from the 4K frame, not windowed as if you are shooting 2K R3Ds. So, the ProRes would all be the same frames just like the R3Ds. Perhaps I am misunderstanding what you are saying?
Yes, if you are shooting 4K, using the same REDCODE RAW Compression Ratio, same frame rate, same ISO, and all 3 cameras are using the Standard OLPF (Raven does not have an interchangeable OLPF); everything looks the same.
In 4k crop, all cameras are the same. However if you eliminate the 4K crop and went 2K ProRes (which is down-scaled from the full sensor), since each camera has a different sized sensor, you'd end up with a different FOV from each.
yeah but its being scaled down from whatever resolution you are shooting the raw from, so if he is shooting each camera at just 4khd, then the scaled down 2k prores file should be the same fov.
you are talking about if he is shooting the raven at 4.5, the scarlet at 5k and the weapon at 6k. which is not what he is asking.
That's interesting. I didn't realize that the ProRes defaulted to full sensor if shot alone.
Correct. Which is why I directly mentioned that I was referring to differences other than what he had asked. :)
it doesnt, it goes by whatever the format you choose to shoot the raw, even if it's disabled.
Also true. I was just pointing out that when not in any sort of crop mode and recording ProRes, the resulting 2K image would be different from each camera. Seems I've just confused people. :)
OK - thanks for the clarifications. I did start out by assuming the intent was to match frames, so I guess the responses were confusing. In the end, you can match the ProRes recordings for the cameras, which is what I would have expected.
yup, the only change in FOV will be when you go above 4khd on the scarlet or weapon, then it would be wider.
Yup. Jordan is spot on.
The thread was about 4k vs 4k vs 4k, but that made me think of how the 2k vs 2k vs 2k could be different under a specific scenario.
And also very much different quality as you both crop of the lens qualities and pixel count on 4k to proress 2k in comparison to 6k to progres 2k... So one would have bigger grain, less lens sharpness and more narrow fov.
Then the weapon trumps on having the possibility to shoot higher frame rates and also higher bit rates if wanted.
but yes the weapon can shoot at the same low quality as the raven, but the raven can never match what is possible to eak out of the weapon.
2K ProRes and the eventual DNxHD/HR support are scaled from whatever format and resolution you are filming with. It's not always the full sensor if you aren't using the full sensor. For instance, 3K HD gets scaled to 2K ProRes in a 1920x1080 Quicktime. or 4K FF would get scaled to 2K ProRes in a 2048x1080 quicktime.
Each of the DSMC[SUP]2[/SUP] bodies indeed have different maximum sensor sizes however. 4.5K Raven, 5K Scarlet-W, 6K Weapon, and 8K Weapon. There are a lot of format choices and resolutions found within each of those.
Ok thank you for your answers!
is there a general improvement in downscaling with larger sensors? ...8k vs 6k vs 5k vs 4.5k
you think there will ever be an upgrade to ProRes/DNxHD for the Scarlet Dragon using the entire 6k sensor?
would this be better downsampling than the 5k sensor on the Scarlet-W?
Down sampling provides fairly predictable results and visual improvements.
If we are talking about finishing 4K you will see benefits from capturing at 4.5K, 5K, 5.5K, 6K, 6.5K, 7K, 7.5K, and 8K resolutions and scaling down to 4K.
The main things you see are in regards to detail and noise/texture/grain. Detail essentially is better while appearance of noise/texture/grain is slightly reduced the higher resolution you capture at and the lower the resolution you scale down/down sample to.
I do not think there will be an upgrade to Scarlet Dragon that allows ProRes/DNxHD/HR because there's no hardware encoder chip in the camera, nor is the board design there to allow for those streams to happen. You need the hardware to make it happen and that's not something found in "OG" DSMC bodies. The upgrade you want is Scarlet-W as that is the upgrade path with the DSMC2 hardware as it does allow for this. As for allowing use of a 6K sensor area, the upgrade path there would be Epic Dragon or Weapon.
There are subtle differences between Scarlet Dragon and Scarlet-W when it comes down to it. Both are using the Dragon Sensor Technology. However, the optics in front of the sensor and the boards behind the sensor do provide a fairly noticeable difference in image quality. The addition of better/lower REDCODE RAW Compression Ratios on Scarlet-W alludes to another way to improve quality.
Yes down scaling is the answer to the best looking HD ever, no noise, looks great, sharp... Camera makers were downscaling before red for same reason with some models
