Dermot Shane
- Mar 6, 2009
I dont know much resolve but it must be fairly easy to make three nodes where you in the first make the r b curves to a flat line and then desaturate the result to zero that node is then your G chanel. Then make one for B and one for R then you toggle between those three. Would that not show you your chanels seperatly in BW?
Then you can treat those black and white images seperatly for example you can make some really cool beauty passes by being able to remove a certain frequency of noise within a channel etc.
to combind the three again into a rgb picture you simply use the three black /white images and pipe a 100 % red blue and green image into the corresponding key and then add them together with add transfer mode.
yes it does all that quite easly, a prebuilt splitter->R-G-B->combiner node tree is one button push away at all times
But its odd that resolve does not have r,b,g keys as hotkeys to see channels seperatly then hold in all three to get back to normal again
and that's what it does not do... and i find it odd too
