Mark K.
Hi Guys,
I recently went through a bit of a debacle with a set of Matthews Triple-Riser combo stands I bought - basically they're much bigger packed down, than is stated online, so they wouldn't fit in my ute. This forced me to get rid of them (at a rather frustrating loss), and now I need replacements.
The maximum closed length I can fit into the ute is 1.45m/4.75', which rules out every triple-riser combo in existence except for the Kupo 'Master High Cine Stands'. Which I've never seen with my own eyes (they're not a common brand down here in Australia) but I've seen some Kupo gear and it's been very nice.
Double-riser combos don't go high enough, so they're out of contention too. However I've stumbled across the Avenger "A3042CS Medium Overhead Stand"
And it seems a good match for the specs I want - goes up to 4.2m high, supports up to 40kg, Avenger's terrific build-quality, and it packs down to just 135cm in length.
I'm sure it'll be great for supporting my 12x12 overheads, but I'm wondering if there are any gotchas I should look out for when it comes to using the 'overhead' stands to support lights? Is the way the legs are more horizontal than a conventional combo stand likely to make them less stable or capable of supporting a heavier item above them? What's the catch?
My biggest lights at the moment are a 1.2k HMI PAR and Arrilite 2000s, so there's nothing too big they'd have to support. The biggest units these stands would likely be used for are an Arri M18 or a 5K Fresnel.
Any help would be much appreciated - as it's damn near impossible to find info on overhead stands online.
Mark
Mark
