Christoffer Glans
I've been advocating for opening up the possibility to use the in-camera tracking (gyro etc.) to be able to post-stabilize footage in the same way that the SteadXP does. But so far it's only been met with "well, some VFX people on big productions are already doing this". Which doesn't really advance anything for the common Red user.
But there's another application that I'm much more intrigued by and it's the way such tracking can be used for getting a virtual camera without the need for post-camera tracking software. I've been in talks with SteadXP about this, but I think they are too small as a team and their user base is primarily GoPro users and amateurs rather than producers of larger productions. Their tracking essentially gives you a virtual camera in post, but it's locked into their own software and the synced files aren't open to be transferred to other softwares.
What would it take to be able to make a script that pulls the in-camera tracking of a Red into a virtual camera in After Effects or Fusion? The things that need to be inputted by the user, or drawn from the metadata is the sensor size (and sensor crop) together with what lens. Then the ability to scale the virtual camera.
I find it rather weird that we are still doing camera tracking the old way using Syntheyes, AE, Fusion camera tracker etc. when we should be able to just pull in a camera track virtual camera directly from the metadata of the camera. Why is this not a thing that is available as a script or plug-in? If I had the coding knowledge I would have done this years ago. Can someone explain why this has not come to be yet?
