Michael Hastings
- Dec 29, 2006
- Florida
- www.aquavideo.com
Indeed!
How much did they charge you, and will they do them again? I need some gears too!
Amund
Amund, the numbers I quoted earlier are partly based on the price ET charged. approx. $4K for focus and iris plus install. As you know, it is fussy, time consuming work. There is a good reason why I continue to push Birger which eliminates the needs for gearing since it uses the internal motors which every EF lens has (or almost any modern SLR lens for that matter, once the other smart mounts become available) - so not only eliminates gearing but works the same with any of the lenses with no modification or adjustment to controls or the housing when you switch among even greatly different lenses.
