- Banned
- #741
Pawel Achtel
Banned
- Oct 12, 2007
- Tasmania
- www.achtel.com
I think everyone in this thread would be interested in your results. I would be very interested to see how well it works. I think you will struggle with CA and contrast.Don't know if anyone is still interested but I got my hands on a Rebikoff port this weekend it is a little beat up but optically clean. I am thinking about building a housing around it. It was originally set up for the 5.9mm Angenieux which I also have and may use for 2K projects BUT since this post claims that any focal length lens will work with the Rebikoff I am going to check it out on the 18-50 Red Zoom tomorrow and the 10.5mm Distagon to see if I get corner to corner coverage in 4K. Anyone interested can contact me for the results. georgem@sea-cam.com.
One of the options which was considered when designing CinePort was to use doublet to correct chromatic aberrations. I have drawings and specs of a fully corrected doublet using combination of optical glass of two different refraction coefficients (B270 and LF5 Scott glass) . It is higher quality than Rebikoff port described here. After ray tracing and analysis by an optical engineer it was decided that a better solution will be achieved using a specially designed dome (now known as CinePort).
Anyway, if anyone is interested I can on-sell the design. It contains all technical specifications needed to manufacture optical elements by an optical workshop. I have abandoned this design :bye2:
