nick allsop
My top handle is the wrong way round as well. i will take it in to Red Europe tomorrow and get them to sort it out.
I can't get it to come off no matter what I do. Granted, I don't have a vice here, but simply mounting it doesn't work.You could have simply mounted the top handle and used a wrench on the flattened parts of the rosette part, or attached a dog bone to the rosette and turned it like a handle.
Is it possible to add the Touchscreen to a Noga arm? It'd be great if someone can post a photo of what the bottom mount of the touchscreen is.
Looks good, how did you remove the front rosette part of the top handle? Can you just unscrew it?
Here it is guys. Works just as well on the 5." All credit to Ketch Rossi on this one. Remember to pick up some half "non threaded" screws to get it secure.
Thread begins at page 110. http://www.reduser.net/forum/showthread.php?58043-KETCH-ROSSi/page110
Here is the bit on the screws. http://www.reduser.net/forum/showthread.php?58043-KETCH-ROSSi/page114
Ok thanks, i tried with all my power to turn it, is not going to work out, i'll go somewhere where they can lock in in a bench, How did you remove the rubber part to relocate it to the other side, without damaging the rubber?
It puts the monitor in the same exact position as my solution - only an inch more forward (which actually might interfere with some lens setups). And You need to buy more parts... Not sure if I see any benefit...
Peter
