Calvin Day
- Dec 16, 2014
Would you be so kind to link the latest firmware update?
Did you find a solution for this? I have the same problem.got my unit.. anyone else have trouble with the hand grips.. the work but the motor starts freaking out and spinning fast in both directions
I have problem with the calibration. When i press auto-calibrate the motor start spinning but when reaching the end on the lens, the motor keeps spinning and at the same time de-attaches from the "lensring". Anyone know how to solve this?
I found a video on youtube of a guy who had the same problem. Apparently its because the voltage is to high and the torque on the motor is thus very strong. I solved the problem by pushing the motor a bit with my hand, but the best solution is to find a lower voltage p-tap connection. The motor is currently getting power from the p-tap connection on the Ronin 2 wich has 14.4VWhich lenses you're trying to calibrate? Is your NucleusM motor firmly attached to rod and gears.
When motor is spinning push it with your hand to have better contact between motor gear and lens.
New firmware 18.03.19.2, release date is 18.04.23
New features:
1. Introducing the EZ mode. EZ Mode will help you link all of the devices to the same channel automatically.
https://www.youtube.com/watch?v=1YLIexGLuBc
2. Save lens calibration data when you switch batteries.
3. The whole system will function under one channel but will also maintain the original channel logic. (Separate channels)
4. It will enable a 4th motor option.
5. The Run/Stop glitched issue is fixed.
6. The Zoom speed will be saved when the Iris knob is set to "0".
7. The motor LOW TORQUE firmware is also included.
Here is the link for the new firmware.
https://drive.google.com/open?id=1lhT9dWqN-0kl7iuepUNWGx0WsiRn4EAU
UPGRADE INSTRUCTION
1. Connect FIZ unit to your company via a USB cable, you will find a TILTA drive.
2. Drag FIZ, MOTOR1, MOTOR2, HANDLE1, HANDLE2 file into the TILTA drive.
3. Unplug the cable and recycle the power of FIZ unit.
4. For FIZ upgrade, go MENU-SYSTEM-UPDATE, it will show V18.04.23, press OK to finish the upgrade for the FIZ.
5. For handles, connect one handle with the FIZ by 7pin to 7pin motor cable. go MENU-SYSTEM-UPDATE on FIZ. It will show UPGRADE JOYSTICK, press OK to finish the upgrade for this handle. Repeat the steps for another handle.
6. For motors, connect one motor with the FIZ by 7pin to 7pin motor cable. go MENU-SYSTEM-UPDATE on FIZ. It will show UPGRADE T03M, press OK to finish the upgrade for this motor. Repeat the steps for the second motor until the FIZ shows NO FIRMWARE.
7. If you have a third motor, repeat step 1 and drag only the MOTOR1 file into the drive again, then repeat step 6.
UPGRADE TROUBLESHOOTING
1. If the computer doesn't read the FIZ, please try with another cable.
2. If you see the ERROR! during upgrading, please try another motor cable and also make sure the battery is charged.
3. Make sure the upgrade file matches the part. If you mistakenly upgrade the motor with handle file which shows UPGRADE JOYSTICK, please reload the motor file into the motor. Vice versa to the handle.
4. If you put more than 5 files in the drive in the same time, it might cause incorrect display.
5. This firmware should fix majority interference which caused by human error, if you still have interference issue, please contact service@tilta.com , we will do our best to fix for you.
Everything works fine until i try to update the motors. It just says "update joystick". I tried to reload the motor files but it still says joystick.For those without Facebook:
Does anyone know where I can find a rosette extender like I circled in the link www.imgur.com/a/g1rIx5p? It's the accessory that attaches to the top of the monitor and the Nucleus handle via rosette. Thank you!
