Peter Lyons Collister ASC
- May 23, 2008
You can set presets: A to B, B to C, C to D, A to D etc. But I am not sure if you can save these indefinitely
Just received ours and can't wait to put it to work! However I can't really figure out what kind of cable is required to enable the REC-button. We're using it on a Scarlet-W with the V-lock expander so I guess it's to be triggered from the 4-pin lemo CTRL right? Can anyone enlighten me or guide me to a cable that'll solve my struggles of the day![]()
got my unit.. anyone else have trouble with the hand grips.. the work but the motor starts freaking out and spinning fast in both directions
I have def tried to calibrate multiple times as well as all the channelsit sounds like either the handgrip knob needs to be calibrated or you're having channel interference. Daniel Stilling made post on thed FB Tilta page sugesting tht you run each of the handgrips and their matching motor on a different channel.
as always...you get what you pay for...for the price it has many features and for starting out it could still be a good option tho
Clayton, don't enter your troll mode please!
I was just saying, after having used one on a job on our C-CAM and reading other comments, that AS ALWAYS you get what you pay for...that's all.
IE don't expect miracles here.
But as a starter kit or as a backup unit it can be ok.
I said the same about the DJI Focus...and the same can be said about the Redrock (at least the first couple of generations which I use from time to time).
Generally I'd say that probably there is no kit under 3/4k$€ really usable in production and reliable enough.
I personally use a couple of RTMotion kits and I think these are like being in another galaxy he he
BTW I even find the WCU-4 not that great!!!![]()
