Paul Watt
I can't seem to get the Bartech BFD to fire the camera. I've got the cable running from the receiver to the Epic on/off cable (http://www.innocinema.com/fstop-bdr-epic-tm-on-off-cable.html)
and into the sync input on the Epic. The Brain GPIO is set to General Input/Record Start/Record Stop/Record Indicator Out.
I've tried mixing those around a bunch, but no matter what, the cam doesn't fire when the RUN/STOP is flipped on the BFD (Currently set to MOMentary rather than CONtinuous - but switching that doesn't change anything). Also, the box on the Epic on/off cable is flashing green when I toggle the RUN/STOP on the BFD, so I'm sure the signal is getting that far.
Any hints on what I'm missing? Or maybe I've got a bad BNC to 00 cable?
Thanks a ton.
Thanks a ton.
