Sony A7S III - Supreme Compact 4K
So FX9 works like an A7MK3 when shooting normal and slowmo.
A7siii is Full Frame 4K resolution, which is similar to the Alexa in pixel pitch... no, the FX9 has a full read of the 6K sensor and downsamples in-camera to 4K
going to have to be a throw down on any camera that can be used in a Ronin-S -- Test Color space/accuracy, Dynamic Range and Sharpness
I can read "No recording limit" (30 minutes limit) is this really so?
Yes. However, if it's running on a very hot day in direct sunlight, it will eventually overheat. It's an extreme case, but the Panasonic cameras will keep going where the Sony needs a break.
Since the noise performance is so good in underexposure, this may be a viable approach.
Yes, that is something that you can't really do much in 8-bit AFAIK, even with clean output.
FX9 is not FF when recording 50/60P...in 4K
In my previous post, I linked to all the modes on Chapman's website.
6K downsamples to 4K 1-3-fps
No Crop, Full Frame, 2K read 120fps
4K S35, 1-60 fps
They have a Venice camera that does all the 6K output, I assume.
