Kenn Michael
- Dec 28, 2006
I only have CH1 enabled. Still hissy.
Good to know they are aware of the DC offset.
I reported the DC offset to Red last week, the hiss is gone on my camera w/ Build 13 if I only enable CH1 and CH2.
Do you have all 4 channels enabled? Try enabling only the channels you are recording to and you should lose the hiss.
The preamps are unbelievably noisy. I have my preamps set at 20db and the hiss is still very much there. Audio is clean with the line inputs as eclaire has pointed out.
It'll be interesting to see if they can get rid of the hiss as another software fix instead of swapping out the hardware.
I'm a post audio mixer as well, and I'd call this amount of hiss disastrous on a mix stage.
One additional question. When you were using the 302 mixer, was there a high pass filter (low cut) engaged? There is a noticeable shift in LF portion of the noise spectrum compared to the NGSX2 mixer
Can you choose to set all four channels of audio in the camera to record from one of the inputs?
Advantage here is you can set someones lav mic or the boom to record on 4 channels and set each channel at a different level. That way if the subject gets quieter or louder then expected you will still likely have a clean good level recording on at least one of the channels and can select in post. I have used this system very successfully before on other cameras and it will be great if you can do it with the red.
I reported the DC offset to Red last week ...I was told they are working on it.
I was shocked not finding pots on the camera.... Even my
hvx has them!!!! What gives on this jim? We are pofessionals here this is not acceptable,
Anybody got rid of hiss by not using line level?
I mean, if you use phantom power and mike level, will hiss go away?
