Gunleik Groven
REDuser Sponsor
Hi.
I guess I will test for this, but still, here is the question.
If you are grading in a REC 709 environment and select jpg2k/P3 as output format, will the signal go through REC709 with a transform to P3, or is the signal set up to have a P3 output LUT instead of a REC709 LUT for the output?
In short, is this a viable temporary solution if one does not have the ability for a calibrated P3 environment?
Best
G
Best
G
