Harry Clark
Hey guys,
I know that the general gist of my question has been discussed ad nauseum, so I'm mostly looking for an answer from the Red Team, or comments from other users regarding my theory and procedure...
I'm shooting a job under stadium lighting, supplemented by HMI's. I need to do some off-speed stuff. I will have an opportunity to test on the scout day.
I normally leave my cameras in "RELATIVE" shutter mode. From a film guy's perspective, this is more "normal" than "ABSOLUTE". You increase frame rate, and the effective shutter speed shortens correspondingly. The angle stays absolute (confusing considering Red's choice of nomenclature)
We went round and round in earlier posts regarding shooting 23.98 time based footage and the need to either make your shutter "NORMAL" or "ABSOLUTE" and adjust accordingly, OR make your off-speed frame rate an upward increment (40.002 fps instead of 40 or whatever)
http://reduser.net/forum/showthread...Time-Base-not-at-24-Time-Base-Rolling-shutter
That was Red One MX, not Epic, so I'm going to revive this and detail what I think will be a good starting point.
I think what I need to do is switch from my normal shutter speed viewing (from ANGLE to TIME) for convenience and brain assistance. I need to switch the mode (from RELATIVE to ABSOLUTE). When I go to 60 fps (which is really 59.94) or 120 fps (which is really 119.98) I need to manually dial in 1/120 or 1/240 respectively. If I don't change the shutter angle, I'll end up with a longer exposure time than I would ordinarily expect/ want. If I leave it in RELATIVE I will surely get flicker.
Again, I will have the opportunity to test on location under the lights, adjust, experiment. I'm just hoping for feedback regarding my expectations and procedure.
Harry
Harry
