We were shooting a commercial and there was an error in continuing to record, then the yellow tally came up and the media was not recognised. We tried to power it down through the LCD touchscreen and REDMOTE but did not work so we disconnect the power connector (which is connected to a RED V-Lock Battery). Reconnected the connector, powered it up and it was fine. We break for lunch then came back to the camera. Powered it up and the everything in on the LCD screen was fuzzy, grainy with green and blue colour. We used the SDI output and tested whether it was the LCD cable's problem but turns out the SDI output is giving out the same result. So we rebooted the camera multiple times and its fine sometimes at first but then goes back to to the same result after or straight away. We finally got 1 reboot that is working, pressed record to do a test and the yellow tally comes back up and we cant power it down, and it doesn't recognise the media again.
Never had this problem before until today.
We were shooting 4k HD, 25fps, ratio 5:1, firmware v3.0.0
We went through the manual and cant find a solution for it.
