Sensor Calibrating question
Antonio Forjaz
55
Maputo, Mozambique
www.pipasforjaz.com
Hi,
When I black shade my Epic keeps on going to 24FPS (varispeed) when my project is actually 25FPS.
Any idea why?
I thought it would calibrate at the setting I have chosen before calibrating.
Any ideas?
Thanks for any help
Antonio
Hi,
Any idea why?
Any ideas?
Thanks for any help
Antonio
There are 2 options for BS, I think your using 'factory' try the other, not that it will make the slightest difference in the grand scheme of things. I always warm the camera for 45 minutes set 1/100 exposure, it gives the most usable range. 12fps -240fps IIRC
No, I am not choosing the factory I am using current, and it changes from 25 to 24 and the 24 is yellow. This just does not seem right, that is why I was asking this question
I think it's just a UI bug. Even if you choose "current FPS/exposure" at non-film rates it shows 23.98 on the display as it's processing.
Ok, so it should have no influence on the actual Black Shading?
