Brian Iannone
- Sep 7, 2011
Can SCARLET be configured with the RED Touch 5.0" LCD, Dual/Quad REDVOLT Module and REDMOTE, but without a DSMC Side Handle?
yes. without a redvolt module you need the ac power adapter or legacy items.
The original post asks if it's possible to configure Scarlet without the side handle but with redvolts.I do believe so, but then you can only power via the power adapter...
The answer is yes, it works exactly like Epic. You don't need a side handle in your kit in order to power or operate the camera, providing you use a battery module along with a touchscreen or redmote.
Yes, Brian, it will work.
Whoa whoa, so you can control the camera and all its functionality solely via the 5.0 Touch Screen?
Is everything that you'd need to run it, but you'd attached to an outlet. Is there any battery solution for $450? If so, that'd be swell. I'd much rather do it this way, rather than having to deal with getting the Class-9 batteries across the border via shipping.
When looking under purchase options for a Scarlet body you see "Display: RED Touch 5" LCD or BOMB EVF (BOMB EVF requires DSMC Side Handle or REDMOTE to navigate menu)"
This tells us that everything is entirely controllable by either the RED Touch 5" LCD, DSMC Side Handle, or the REDMOTE. Any should suffice.
