Scarlet-W Base Expander audio problem
Gerrit Piechowski
Germany
www.modestdepartment.com
Hey guys,
I just came from a ten day tour, filming a documentary in italy about a cycling team.
I was running my Scarlet-W setup and purchased a RODE Videomic-Go for scratch-audio and brought my RODE Link for interviews etc.
I've read a lot of good stuff about the very cheap (68$) RODE Videomic-Go and never had any problems with my RODE Links - in fact they are pretty damn good for that price.
I ended up recording all the audio with the built-in mic of the RED Scarlet-W because it seemed that the audio-port of my base expander wasn't working (and yes, I did check Rear Analog in the Audio-menu), has some loose connection unfortunately since sound is coming every once in a while with ugly cracksounds/distortions.
I'm not really sure what it is, but I wasn't able to just plug my audio-equipment into the port and have it working.
Now coming to my question:
• Is it my base expander module?
• Is it a firmware-based problem?
• Has it something to do with RODE products?
• Is there anyone else having problems like mine?
• What can I do against it?
Thanks in advance for any kind of help,
Gerrit!
The Røde Videomic Go page says "Requires 2.5V Camera Plug-in Power". Where is that 2.5V source coming from?
When I used RÖde it did not work to plug straight into red camera. But if you find the a thread here it´s just to take it apart and cut of a cable inside the microphone and all should work fine. I think it´s the white cable that needs to be cut off. and taped up inside.
Edit found the thread.
http://www.reduser.net/forum/showth...-RODE-VIDEO-MIC-PRO-working-with-Scarlet-Epic
Yes, but...SCARLET-W's base expander is yet different from EPIC/SCARLET mic jacks.
The DSMC2 expanders don't supply phantom power through the audio jack like the DSMC ones did, but I haven't read anything about whether or not it will supply 2.5v - it probably doesn't. I'm thinking that's why it won't work. You could try one of the other self-powered Rode mics like the video mic pro which has it's own 9v battery and see how that works out. I have one I could try, but no camera yet :(
